drive by wire questions?
I would talk to whoever is going to make your harness first and see which pedal they like to use. Speartech likes to use the Corvette pedal on the LS3 systems they do, and I like it as well. It is very easy to mount, and the arm can be pie cut and welded back together to change the pedal position. There are a bunch of pedals out there, that have a composite arm, which is pretty much impossible to change the geometry of. Not all pedals are the same, so you will be better off in selecting the harness first so you can be sure that the harness will work with the pedal.
Regards, John McGraw
LS1Tech Sponsor
For the LS3 applications we like the Corvette Pedals as well. We have new GM pedals in stock.
Jon
PSI
Jon
PSI
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
