In line fuel pumps
Old 02-03-2012, 10:01 PM
99VetteFRC's Avatar
Default In line fuel pumps
I am looking to go with Aeromotive A1000 inline pump for my Chevelle project. I was wondering what pumps all you boosted guys are using in your conversion setups and how much are they? Thanks for your input!
Old 02-04-2012, 12:32 AM
2165 Turbo Rail's Avatar
started with a walbrow 255 but had 2 of them crap out so switched to a Bosh 044 and so far so good
Old 02-04-2012, 06:36 AM
99VetteFRC's Avatar
How much was it and where did you get it.
Old 02-04-2012, 08:24 AM
eBay. You can find them with the AN fittings for about $260
Old 02-05-2012, 07:23 PM
CBAR02SLP's Avatar
Default Fuel Pumps
If you plan on extended cruising where ambients might reach 90 F, my rec is to stay away from in-lines!! They will let you down in the heat (PM me if you want all the details).
Aeromotive offers the 1000 in an in-tank set up (a recent Hot Rod had an install in their yellow Chevelle?), contact Bret at ext 109 and he will give you a ton of help...BTW, Weldon has great pumps as well (in the price range, $350, you're looking for).
I'm boosted, have been chasing this problem for a long time, and have finally solved it...if it's going to be hot, go in-tank!!!!!
BTW, check out one of the guys in "conversions", a '60 something BelAire or Impala, I believe. He's got a neat use of a late modle GTO system...returnless?
Good Luck
Quick Reply: In line fuel pumps
