Need radiator hoses for 70 Monte LS Swap
Old 02-08-2012, 01:03 AM
1975delta88's Avatar
Default Need radiator hoses for 70 Monte LS Swap
I looked in the search but there aren't any 1st Gen MC LS Swaps. The hoses I want are just the regular off the shelf ones. I don't want the aluminum vacuum cleaner hose ones. I changed my radiator so that the inlet and outlet are both on the passenger side. Since the MC has quite a bit of space from the water pump to the radiator, I'm not sure the regular A-body swaps will be long enough if you have this type of radiator.
Old 05-13-2012, 09:20 PM
samckitt's Avatar
I just happened to be looking on Summit tonight for one for an 86 Monte. I don't need the trans cooler because I am using a manual trans, so I can get away with the cheaper one. But I changed the year to 1970 and found these:
http://www.summitracing.com/parts/GRI-8-00010-LS/
http://www.summitracing.com/parts/GRI-8-70019-LS/
I have no experience with either, so I can't say anything good or bad about either.
Good luck
Old 04-20-2014, 02:20 AM
That's the exact radiator I bought for the 70 Monte
Quick Reply: Need radiator hoses for 70 Monte LS Swap
