2nd Gen Camaro LS1 Vintage Air Trinary Switch Wiring
Old 02-14-2012, 08:54 PM
1970RSZ28's Avatar
Default 2nd Gen Camaro LS1 Vintage Air Trinary Switch Wiring
Hi everyone... just trying to see if I am on the right page before I wire up this trinary switch on my car.... First pic is of Vinatge Air's wiring schematic, Second one is my own, and finally the last one is for the Flex-a-Lite Black Magic Fan.... It already has a relax box attached to it....
Attached Thumbnails 2nd Gen Camaro LS1 Vintage Air Trinary Switch Wiring-vaschem.jpg   2nd Gen Camaro LS1 Vintage Air Trinary Switch Wiring-myvaschem.jpg   2nd Gen Camaro LS1 Vintage Air Trinary Switch Wiring-untitled.png
Old 02-14-2012, 11:47 PM
garys 68's Avatar
You could wire the trinary switch to provide a ground or + voltage to the relay. It's typically easier to find a ground near the trinary switch location though.
Old 02-15-2012, 02:31 PM
1970RSZ28's Avatar
that's what i think i'm getting at with the second pic....right? Haha now im doubting myself...
Old 02-16-2012, 12:15 AM
1970RSZ28's Avatar
I see what you are saying now.....but the fan has an A/C relay built in to it but it requires a 12v input (It only requires 110 milliamps to trigger) Would it be ok to run that through the vintage air switch?
Old 02-16-2012, 04:34 AM
garys 68's Avatar
yep, just make sure the relay isn't set up with a common 12v source for the high amp feed and trigger
Quick Reply: 2nd Gen Camaro LS1 Vintage Air Trinary Switch Wiring
