A-body clutch master cylinder intall??
Old 03-02-2012, 04:13 PM
Ls3Chevelle72's Avatar
Default A-body clutch master cylinder intall??
does anybody have any build threads, on intalling one of these things, i ordered the hydramax hydraulic clutch kit. as of now i have an automatic, im looking in the general area of where it would go and i dont see any holes or dimples. it looks like there would be no space and its pretty intimidating.. this is on a 72 chevelle
Old 03-23-2012, 11:31 PM
lq4elky's Avatar
I don't know the hydramax clutch kit but I used a factory ls1 camaro master when I did mine. I used a bracket to hold it at the right angle and used it as a template of where to drill my hole. It was below the brake booster and slightly toward the drivers side of the car. If the master cylinder you have doesn't have a bracket then you need to get your clutch pedal mounted figure out how to mout you master cylinder so it is a straight shot from the pedal and drill a hole thru the firewall. Hope that made some kinda sense.
Old 03-24-2012, 02:22 AM
Thanks very helpful
