oil pickup clearance
Old 03-05-2012, 05:47 AM
abadbowtie's Avatar
Default oil pickup clearance
I have a 05 4.8 I am putting in a 55 belair I got the pan cut down yesterday I am using the truck pan. Before we weld the bottom back on I am going to finish the pickup tube shortening. What is the correct clearance on these ls motors? Right know I have it just tacked and I have 3/8 clearance. Want to make sure before I final weld anything.
Old 03-05-2012, 08:01 AM
bczee's Avatar
When I check clearance with my RetroLSx (now Holley) pan.. I put some clay on the pickup and I had almost 3/4" between the pan and pickup.
BC
Old 03-05-2012, 08:22 AM
abadbowtie's Avatar
3/4 seems like allot I didn't think they were that much
Old 03-05-2012, 08:50 AM
bczee's Avatar
well.. too little can cause engine starvation. I have read of that happening before. I had always heard or thought 1/2" was the correct clearance.. just saying..
BC
Old 03-05-2012, 10:47 AM
abadbowtie's Avatar
I did a bunch more searching and am reading on here were .300" is the correct setting. So I may just double check my measurements and go from there.
Old 03-05-2012, 12:03 PM
Jim85IROC's Avatar
1/4" to 3/8" is generally considered ideal. .300" would be right between the two.
Quick Reply: oil pickup clearance
