LS6 cam & Pushrod ?
Old 03-07-2012, 03:59 PM
Daz
Daz's Avatar
Default LS6 cam & Pushrod ?
I'm using a 2004 LS6 cam and valvetrain on my 4.8 turbo build. I heard that with I have to use a little bit longer pushrod cause the cam is slightly smaller in radius. What size rod would be appropriate ? Stock is 7.4 right ?
Old 03-07-2012, 06:18 PM
bczee's Avatar
Yes. the Later LS6 cam use the small base circle and you would need 7.425" rod.. The difference is the a LS6 engine used longer Valves in the Heads as compared to the LS1 valve/heads.
BC
Quick Reply: LS6 cam & Pushrod ?
