Flywheel/flexplate cover with aftermarket pans?
Old 04-11-2012, 09:52 AM
LSxChevelle's Avatar
Default Flywheel/flexplate cover with aftermarket pans?
So I was looking at the Mast pan and then it dawned on me that I can't use a factory flywheel cover. Still considering a CTS-V pan as it is cheaper and can use the plastic flywheel covers but concerned about steering linkage clearance.
Is everyone that runs a aftermarket pan making their own cover? Or running without? Not wanting any debris to get near my Spec billet dual disc setup...
Jason
Old 04-12-2012, 05:22 PM
I called American Powertrain to see if they make a full plate like Ford's use between block and flywheel but they don't...
Old 04-12-2012, 08:29 PM
Gray86hatch's Avatar
I have not used one. never found anything in the bell
Tim
Old 04-12-2012, 09:50 PM
I wouldn't worry if I had an auto... Just a little worried since this clutch new is like $1800! I bought it barely used for $550 though.
Old 04-13-2012, 03:30 PM
This is on dads stick car. Unless you are driving down dirt roads I would not worry. It would have to get past the flywheel first and would be very very bad luck if it happened
Tim
Old 04-13-2012, 04:15 PM
Ok, good to know. I may end up running a CTS-V pan which I could use the black plastic panels with.
Old 04-13-2012, 04:29 PM
We are using the holley pan no clearance issues with anything.
Tim
Old 04-13-2012, 05:10 PM
Rocketrod's Avatar
I used the black panels by drilling a few pilot holes in the housing and secured them with #6 sheet metal screws.
Quick Reply: Flywheel/flexplate cover with aftermarket pans?
