LS swap shifter??
LS swap shifter??
Hey Guys. What are you guys using for shifters with your 4l80e swaps?? Do they have to be 4l80e specific or any one that can work for a turbo 400? Thanks!
ive done that. lol it comes up with only lokar. i seen some guys running the pro stick but it doesn't list it in jegs. Plus I know there are other options than just lokar and one hurst.
What kind of car?
Check out shiftworks, which is where I got mine for my 68 camaro. It just converts the stock horseshoe shifter, which I thought was the coolest.
http://www.shiftworks.com/camaro-68-72.htm
grand national. thats the thing. I have nothing. I can put any counsel or shifter with cover I want. just looking for options. Can I get any aftermarket and then order the 4 speed plate for it?
I have a B&M Quicksilver. It has a 5/16" pin you can remove to get the extra gear. I changed from a th350 to a 700r4 and it worked great. Since the 4l80e has all the switched on the trans, you don't need all the electronics in the shifter. I used it with a manual valve body, and this is the second Quicksilver I'va had and they work flawlessly.
