Brake switch mod for 72 Cutlass
If you're running a manual and set the ecu for that, it will be looking for a clutch pedal position switch. On DBW it looks for a 12 V NC signal, on cable it looks for ground, pins are different too.
I just wired my ecu for switched 12 V all the time. You jusat have to remember to hit the brake or off cruise contro, before you hit the clutch. Otherwise things spin very fast.
I found what my cruise switch looks like from Rosta. http://www.rostra.com/images/2503002/2503002-large.jpg They say theirs is a closed circuit. I found a write up about adding relays to the switch so I'll look into that when I install it.
For cruise on yours, check with these guys. Unfotunately, I expect it to be more than $45.
http://spankysrodshop.net/index.php?...ories&Itemid=7
