header choices 68 Camaro-- Unisteer Rack
are there any specific headers that will work with the unisteer rack?
Hedman Hedders 45066 ?
Stainless Works CALS1SB
they say will only work with a rack-- still havent seen any cars with what oilpan/mounts headers as a package
i have the transdapt plates and have reversed the frame mounts -- still might be too low--
--update-- it is too low-- so far i have 1/2" spacers under the factory mount and the oilpan is just touching the rack cross over tubes so still needs to go up another 1/4" .. mounts are still reversed and the cylinder heads are about 1.5" from firewall .. - can go further back but the more i do the further back shifter is--
the CALS1SB's are actually for a steering box.
The CALS1 part number is designed for a rack and pinion.
-67-69 LS1 F-Body headers.
-1 3/4" 16 gauge 304 Everlast Stainless Primary tubes
-CNC laser cut flanges.
-Smooth formed collectors with 3" slip joint exhaust connection.
-O2 bungs installed in slip joint collector extension.
- Must be used with rack and pinion steering.
