04GTO-t56 stock harness, got it wired, IT RUNS !!!! wooohoo
Old 07-06-2012, 01:09 PM
attilahooper's Avatar
Default 04GTO-t56 stock harness, got it wired, IT RUNS !!!! wooohoo
04 GTO LS1 w stock harness sitting on engine stand;
I'm about to do a baby step and put power to my harness so I can read the PCM with a scantool. I have the following wires connected to C206, but have a question.
So far:
Pins: 6, 7, 8, 13, 18, 21. --> Batt+
Where da hell does this thing get ground ??? Pin 2 (Low reference) ?
I got the DLC connector figured out. 2 grnds, a hot and Pin: 26 yellow--> DLC pin 2 purple
Thanks in advance
Old 07-06-2012, 03:01 PM
OK, wait a sec. I came across this doc in my files....
2004 GTO connections.doc
Looks like C101 is where I feed Batt+ to injectors. Glad you guys warned me
File Type: doc
Old 07-06-2012, 09:10 PM
Figured it out. Hooked up all hots and grnds on C206 and C101 and scanned the ecm.
Old 07-14-2012, 03:13 PM
OK, c'mon now folks. Weigh in w a little advice if you would...
Engine turns and tries to fire, but does not run.
scroll to the end of the vid 0:50 seconds
Power and grounds hooked up as previously described.
C101 has +Batt -> 2,3 (red , lt green)... Grnd at 5 bk/rd
Edit: I see C101 #6 is for A/T rev lock and skip shift.
However, my question about C101 #1(yellow) CPP clutch pedal. Does that need Batt+ to start ??
Edit2: And yeah, the PCM has been programmed. Vats, sec O2 delete, etc.
Old 07-14-2012, 05:11 PM
aknovaman's Avatar
LS1Tech 10 Year
Do you have 60 psi at fuel rail ?
If injectors have set for more than 6 months, remove and soak in kerosene for an hour then re install. Ensure vats is set to none in PCM file too.
Old 07-14-2012, 05:44 PM
Thank you sir. I have some seafoam to soak em in.
yes, 50+psi at the rail.
yes, injectors have been sitting.
yes, VATS should have been canned.
EDIT: I'll thank you again separate on the Impy forum
Old 07-15-2012, 12:21 PM
She's a runnin'. Thanks again AK. Soaked the injector tips overnight in seafoam, and this morn I blew some carb cleaner through them while applying 12v. Nice foggy spray pattern.
Edit: Oh, DMM connected to GN & BN/WH of stock oil press sensor. 1.6 volts at idle, 2.0 volts at fast idle.
Quick Reply: 04GTO-t56 stock harness, got it wired, IT RUNS !!!! wooohoo
