trk accs drive w/ls1 water pump--idler pulley
Old 07-13-2012, 07:24 PM
flywheel's Avatar
Default trk accs drive w/ls1 water pump--idler pulley
lq4 w/ ls3 heads, intake, dbc throttle body. Ive got the ls1 water pump w/spacers, the off set pulley adp for under the Alt. BUT now the truck idler pulley on the pass side doesn't fit on the ls1 pump.....Where can I get the ls1 one? Dealer? Suggestions from those that have done this PLEASE..
Old 07-13-2012, 08:14 PM
Pocket's Avatar
LSx accessories are spaced 3/4" of each other, from corvette to Fbody/GTO to truck. Its a matter of figuring out how big your waterpump spacer is and stepping back the tensioner that many positions
EX:
Truck balancer/accessories, 3/4" waterpump spacer, Fbody WP. You'd need a Fbody tensioner
Same setup using 1 1/2" spacers would use a corvette tensioner
Quick Reply: trk accs drive w/ls1 water pump--idler pulley
