what gauge wire for alternator?
Why is the Ford solenoid chasing you?
I'm not sure what a Ford Solenoid has to do with the alternator, unless you are saying that is going to be your common power lug. Like the horn relay in the following
http://www.madelectrical.com/electri...evymain1.shtml
At any rate I have 4 gauge on mine. Jap cars all seem to use that size wire. That is what was in the harness I grabbed when I got the alternator.
Using a Ford 'noid makes the wire for the starter hot only "during" cranking...nice Little option when running a trunk mounted battery and the 'noid in trunk next to it.
Anywho... I've been running an 8ga. from alternator to battery.
