Installed autometer electric speedo trans quit shifting
Lsxfox 5.3/4l60e
Autometer electric speedo hasn't worked for a while but trans was perfect.
Called autometer they told me to tap into the positive side of the 2 wires that go to the vss plug, did what they said speedo started working. Take off to calibrate it and it wouldn't shift to second, then after 1/4 throttle went into like neutral even though I was still in gear.
What happened?!?!?
I'm kinda freaking out here
What happened?!?!?
I agree. My Autometer speedo screwed my trans shifting up too. Called Autometer and they told me to put a reesistor in line of the speedo signal, made it a little better but not right. After that I did what they said wouldn't work, hooked it to the PCM speedo output and set it for 4000 ppm and it works perfectly.
That's hat solved my issues, dip **** me didn't remember to calibrate the first time. I figured it would read atleast something when first hooked up but no needle didn't move at all, that's why I figured that wire wouldn't work
