Separate Neutral Safety switch required?
Old 09-16-2012, 06:44 PM
1936 LS1's Avatar
Default Separate Neutral Safety switch required?
I'm running a 5.3/4L60e combo and included the PNP switch on side of the transmission just like a factory setup. I'm trying to finish up my wiring harness and had this question... Do I need to wire a separate Neutral Safety switch (there's one already installed on my Lokar shifter) or does the factory switch already perform that function through the PCM?
Old 09-16-2012, 06:51 PM
kwhizz's Avatar
I had to wire in a separate switch in the 37........Good Luck!!!
Old 09-16-2012, 07:05 PM
rockytopper's Avatar
The PNP controls engine idle only does not serve as a safety switch. I wired a separate micro switch that works for park only sense I never use neutral anyway.
Old 09-16-2012, 07:29 PM
1936 LS1's Avatar
Thanks, guys. Wanted to know before I put the trans tunnel for (hopefully) the last time.
Old 09-16-2012, 08:22 PM
ls1nova71's Avatar
You can wire it either way, there is a neutral safety switch in the trans mounted switch, but you cannot just run the starter wires through it like the shifted mounted ones. You'd have to use it to wire in a starter relay. The lokar shifter mounted one would be less work.
Quick Reply: Separate Neutral Safety switch required?
