Question on AC lines for LS1 into 95 Camaro swap.
I've got the LS1/4L60E sitting in my 95 and currently hooking up all the wiring, brake, coolant, and AC lines. I'm using the stock LS1 AC unit. I read on this forum to use the LT1 line but my LT1 AC lines wont fit as they are hitting the headers. Any suggestions on which way to go? Thanks.
Just checking in. I think I solved my AC issue. I order the following kit from
nostalgic air parts. The rotational compressor fitting with hoses and fittings should do the trick.
http://www.nostalgicairparts.com/air...tional-471.php
Thanks
Thanks
