Help 5.3 4 cylinders are misfiring
I have a 68 firebird with a 5.3 and an LS1 intake backed up with a turbo 350. I have gotten it to turn over but there is never the right idle and has no throttle response. Pulled spark plugs, 3-4-5-6 cylinders aren't hitting. changed out injectors-no fix. Coils are good, fuel pressure is at 59 psi. Any suggestions why it might be misfiring? I also spliced in new injector pig tails.
what harness are you using? There will be two switched power wires going to coils.. sounds like either a fuse is blown or there is a break in the connection on the coil pack harness
