02 Firebird LS1 swap - No power to Fuel Pump
Old 12-01-2012, 03:30 PM
Need4Camaro's Avatar
Default 02 Firebird LS1 swap - No power to Fuel Pump
We resolved the starting issue, but now Im not getting power to fuel pump. Checked the #30 connector on PCM and grounded it to try to eliminate any VATS issues but that didnt work.
Old 12-01-2012, 07:24 PM
HOTROD NETWORK's Avatar
The pcm pulses the ground for the fuel pump when you turn the key om,Green wire with white strip.That's what I would check out first.If not,check all the grounds on the back of the head and make sure the motor is grounded correctly to the frame.Good luck...
Old 12-02-2012, 06:04 AM
LS1MCSS's Avatar
Incorrect. The pcm puts out 12 volts to power the fuel pump. It's the only output from the pcm that's 12v. Everything else is ground, but not the fuel pump.
Old 12-03-2012, 12:40 AM
the_merv's Avatar
Is this what you were texting me about the other day?
Old 12-10-2012, 12:19 AM
Default re
You are correct,Don't know why I said ground(Brain fart) lol
Old 12-10-2012, 12:23 AM
Aleken's Avatar
LOL
Quick Reply: 02 Firebird LS1 swap - No power to Fuel Pump
