LS swap, using oem ecm, but not using mass air, what do I do for a AIT?
Old 12-10-2012, 08:55 PM
TDMKR496's Avatar
Default LS swap, using oem ecm, but not using mass air, what do I do for a AIT?
I'm getting ready to do a swap in a 79 Malibu that I'm going to use a PSI harness on (L31, 4l80e, car intake, truck accessories, S475 turbo) I'm not going run mass air on it, and from what I have read the air inlet temp sensor is in the mass air meter, so what do I do??
Old 12-10-2012, 08:59 PM
Grr
Grr's Avatar
if it is the later harness with it in the maf, you can get a replacement IAT plug and cut the 2 IAT wires from the MAF plug, and use a standard 2 wire sensor
Old 12-10-2012, 09:06 PM
i r teh noobz's Avatar
Get a generic GM IAT (I used a 96 LT1 part, but its pretty much the same part for everything back to the 80s). Cut the wires from the MAF plug that run to the IAT circuit (I think its brown and black) and run them to the sensor. The connectors from most of the EVAP and AC stuff works for the IAT.
Old 12-10-2012, 09:47 PM
Vcious04's Avatar
Go buy a GMC Typhoon IAT sensor (3/8" NPT Threaded), chunk all the wires to the MAF except black and tan wire. Go to your local junkyard or auto zone and buy a coolant temp sensor pigtail off a 99up Tahoe and plugs right in. I chose junkyard as I paid $1 for pigtail lol
Old 12-11-2012, 08:32 AM
TDMKR496's Avatar
That's great info guys, thanks. I still have the harness that came with the motor, so I could just cut that plug off and use it.
Old 12-11-2012, 10:33 AM
99VetteFRC's Avatar
Here is a pic of the Tyhoon/Cyclone sensor. I bought the sensor at Advanced Auto for $23 and the pigtail from GM for about the same.
LS swap, using oem ecm, but not using mass air, what do I do for a AIT?-dscn1341.jpg
Quick Reply: LS swap, using oem ecm, but not using mass air, what do I do for a AIT?
