04 5.3L carbed in a 68c10 questions?
Old 02-08-2013, 10:40 AM
68fleetside's Avatar
Default 04 5.3L carbed in a 68c10 questions?
Hey fellow hot rodders, I'm starting this thread because I have several questions on what all I may need for this swap. I have engine and truck already.. I'm planning on going with 700r4... I want to use as daily driver... I got small custom cam..
Some of my many questions...
1. Motor mounts? I had a 350/350 in prior
2. Carb setup? What intake?
3. Trans adapter?
4. Drive shaft will same one as 350 work?
5.whats the best carb to run? (Daily driver)
Can't think of anything else now but I'm sure ill come up with some as soon as I start ordering parts...
Feel free to post ur threads or threads with similar builds...! Thanks guys!
Old 02-08-2013, 10:45 AM
6. Headers? Would stock manifolds for the frame?
Old 02-08-2013, 10:59 AM
Fit*
7. Will I need external fuel pump if I'm running carb? What psi? Recommendations?
Old 02-08-2013, 10:18 PM
hrdrckclmr's Avatar
search for the build threads from ls1nova71 his builds are crazy good at showing how, what, why, he has built two of those and is working on the third one now
Quick Reply: 04 5.3L carbed in a 68c10 questions?
