4L60-E Neutral Position Switch Wiring
Old 02-18-2013, 03:04 PM
Chevy II's Avatar
Default 4L60-E Neutral Position Switch Wiring
I have a 2003 Tahoe 4L60-E Trans. There are 10 wires coming off the NSS on this trans.
1. BLK/W to pin C1-32 (PCM)
2. WHT to pin C1-34 (PCM)
3. YEL to pin C1-72 (PCM)
4. GRY to pin C2-62 (PCM)
5. BLK to GRD
6/7. (2) PNK's to Under hood fuse block
8. GRY to pin A11 (Trailer Backup Lamp Supply Voltage - under hood fuse block)
9. LT GRN to pin D3 (Park Neutral Position Switch Park Signal - under hood fuse block)
10. DK GRN to pin F11 (Park/Neutral Start Swicth Signal - under hood fuse block)
Trying to build a stand alone harness from this harness and need to know where the last 3 wires would come from? I have the underhood fuse block, but don't know what the source is for those last 3 wires, what do I tie them into?
Any help is appreciated.
Old 02-18-2013, 08:27 PM
01cherryreds10's Avatar
Are you sure that's the correct PNP switch? The 4L60E switch should have a 7 cavity connector and not a 10
Old 02-18-2013, 08:32 PM
ls1nova71's Avatar
Are there 2 plugs on the switch? Not sure if you numbered them 1-10 or if the plug is? They should be letters. But anyway, your 8 I think woukld be the power for the back upn lights, but it's a pink wire. the 9 could be the shift interlock. The 10 is the wire that goes from the NSS to the starter relay.
Old 02-20-2013, 02:52 PM
Chevy II's Avatar
It is the correct switch. Came on the motor/trans I got out of the Tahoe.
Yes, there are 2 plugs. I didn't number them in any order as to which plug they go to. I was going more by color and where the wires ran. The ones in question are between the trans switch and underhood fuse box.
The descriptions below are what I found from an underhood diagram, but they didn't give any more information as to where they come or go to.
My No.8 must be the backup light. Does it go to the backup lights or a relay?
My No.9 - where does the shift interlock come or go to?
My No.10 - which terminal on the starter relay would it go to?
Quick Reply: 4L60-E Neutral Position Switch Wiring
