L92 and 6L80e
L92 and 6L80e
Has anyone used this combination of powertrain? My concern is with making it work electrically. Will the TCM talk to the PCM without a gateway module BCM? Does anyone have suggestions on making this work?
LS1Tech Sponsor
Yes. This has been done plenty of times. We have a harness combination for it, $675. Give us a call or pm to discuss.
Jon
PSI
732-691-6531
Jon
PSI
732-691-6531
__________________
Your Source for LSX Conversion Parts!
www.psiconversion.com
Ebay Store
Facebook/psiconversion
Instagram/psiconversion
'Dont Let EFI Pass You By!'
Ebay Store
Do I need a BCM or a gateway? From what I am seeing in the GM wiring diagrams there is not hardwires btween the PCM and the TCM.They communicate to each other through the GMLan or bus to the BCM/gateway. Then the information is sent back to each other.
LS1Tech Sponsor
Correct they communicate through the information bus. You do not need a BCM.
Jon
PSI
Jon
PSI
__________________
Ebay Store
Ebay Store
