help foxbody swap: headlights power/fuel
Old 03-09-2013, 11:55 PM
cordova87's Avatar
Default help foxbody swap: headlights power/fuel
So im working on this lsx swap on my coupe lq9 6.0
im trying to figured out how to power up the headlights do i? use the old ford solenoid or how would i power them up? Here's some pics of what im talking about, also how do i add the fuel pressure regulator intake is return style?
Attached Thumbnails help foxbody swap: headlights power/fuel-headlights-power.jpg   help foxbody swap: headlights power/fuel-pwlights.jpg
Old 03-10-2013, 04:05 AM
topendrunner's Avatar
hook that yellow one to constant power. the metal thing is for the door locks and the red is the starter trigger.
Old 03-10-2013, 06:59 AM
1bad03snake's Avatar
the black wire is a ground. I tapped into a white and pink wire under the dash to trigger my starter solenoid
Old 03-14-2013, 06:43 PM
cordova87's Avatar
K thxs fellas
so the red one cani just connected to the gm solenoid or to the same as the other wires
Quick Reply: help foxbody swap: headlights power/fuel
