Truck oil pan ???
Old 03-10-2013, 10:15 PM
jaywill's Avatar
Default Truck oil pan ???
Fit a79 mailbu with setback mounts...or i need to get another pan ?
Old 03-11-2013, 10:02 AM
Blue Knight's Avatar
Yes it will "fit" but it will hang...
Old 03-11-2013, 10:36 AM
superbean's Avatar
If you have a few exta bucks a much better fit is the Caddilac CTSV pan, it is about flush with the cross member.. a must for any significantly lowered vehicle (I ran one on mine as it's on coilovers) Only problem is they are about $200-250
Another option is the Hummer pan (GM Muscle Car pan).. it is about an inch shorter than the truck pan, so it will adequately clear stock/slightly lowered vehicles. Summit sells the kit for $150 that includes pan, pickup, windage track, dipstick and tube.. not too bad
Or run the truck pan and tip toe over speed bumps lol
Old 03-11-2013, 01:23 PM
jaywill's Avatar
thanks 4 the info...
Old 03-11-2013, 04:21 PM
chuckd71's Avatar
The hummer pan is still going to be the lowest point of your car though. If you are fine with that route to save $100 then yeah it will probably work, and people seem to do it all the time.
Old 03-11-2013, 09:12 PM
llorracs93s10's Avatar
I have a truck pan if you are interested. PM me if you are
Old 03-11-2013, 09:57 PM
jaywill's Avatar
Thanks but i have 1 on my engine..
Quick Reply: Truck oil pan ???
