Ls1 vs lt1 fbody gas pedal
Was not exactly sure where to post this. On another site, this topic got derailed so hopefully I can ask it here.
I'm gathering parts for my LS engine swap from my 3.8. There plenty of lt1 car in the salvage yard here. Question is. Would one of the lt1 gas pedals work for a 99+ ls1 car?
I had to end up using one of the pedals from the trucks, along with an aftermarket cable, as neither of the stock cables was long enough for my application. I also had to fabricate a spacer bracket for the gas pedal because if I mounted it straight to the firewall my gas pedal would be about 3" lower than my brake pedal.
Take some measurements in the car you drive daily to see where they place the pedals in relation to each other. You want the gas pedal to sit a little lower than the brakes, presumably so that you don't accidentally slam on the gas when you slam on the brakes.
I used the stock pedal in my 96 Formula and a 1LE cable from a LS1 car and had to bend the pedal where the cable connects back towards the driver about 1inch. Worked perfectly. I would say try your stock pedal and as long as they hook up the same they are easiyl bent to work.
