bought the PSI f body cluster pigtail but....
theres no wire for the fuel gauge! i need to put the wire in but i dont know the pin location. its a 99+ cluster and sender. any help is appreciated.
the cluster doesnt have an input directly from the fuel level sensor in the tank, the signal goes to the PCM and the pcm communicates with the IPC on the class2 data line to tell it what the fuel level gauge should read.
Iirc theres a link in the sticky for pcm connector pin outs,i used a stock 98 fbody harness on mine which had the under dash wiring.i know the merv has posted a link not too long ago to all the pinouts
http://www.hotrodders.com/forum/gm-f...hm-106069.html
