cam
Old 06-09-2013, 07:25 PM
my406cid's Avatar
Default cam
Poss got good deal on a cam. Specs are @.050; 223in 231ex .638 in .644 ex lsa is 120 icl is 120. How will this cam act in a 11.0:1 l92 headed lq9 with f/i and a 2800 yank converter and a 3.42 rear with the 4l65e?
Old 06-10-2013, 07:31 AM
my406cid's Avatar
Is this im the wrong room?
Old 06-12-2013, 03:01 PM
my406cid's Avatar
Well thanks to all that replied.lol
Old 06-12-2013, 03:22 PM
bczee's Avatar
Would really suggest you use the Internal Engine forum section..
You would likely have to give more specific information.. is this an off the self cam or a custom grind ?.. what brand name is it ?.. type of cam lobe profile... etc..
120 degress is pertty large LSA.. but I'll defer to the engine/cam experts.. I can help you on swapping the LQ9 into something tho !
Old 06-17-2013, 09:47 AM
my406cid's Avatar
its a custom grind by comps cams. and the lq9 is going into a 87 buick regal. any tips are greatly app!
Old 06-25-2013, 12:32 PM
jwcarguy's Avatar
with that lift, you better verify that you have proper ptv clearance!
LQ9 has the flat top pistons
You didn't specify what head gaskets either ( compressed thickness?)
Also, as said before, that is a large lsa @ 120 sounds more like specs for a boost application, rather than N/A
just a example 68' Camaro 6.0L T56 w/ 4.10 rear gears
I am running a iron block 6.0L w/ LS2 rotating assembly (stock flat top pistons), LS3 heads. GM mls head gaskets .054"
custom grind spec'd cam: 226/234 .629”/.629” 113 LSA +2 advance
my pistons are fly cut on the intake side
Just because it may be a "good deal", doesn't mean that it will be "good" for your application
Quick Reply: cam
