Wiring help please.
C-1 Underhood Bussed Electrical Center (UBEC)
Connector Part Information
•12193905
•68 Way F Metri-Pack 280 Series (LT GRY)
Pin
Wire Color
Circuit No.
Function
A1
ORN
40
Fused Battery Feed
A2
ORN
740
Fused Battery Feed
A3
BLK
28
Horn Relay Output - Coil
A4
LT BLU
74
Park Lamp Switch Output
A5
ORN
1040
Fused Battery Feed
A6
BLK/WHT
451
Engine Control Module Ground
A7
BLK
550
Ground
A8
Not Used
A9
PNK
3
Ignition Switch Output - Ignition 1
A10–B1
Not Used
B2
PNK
94
Windshield Washer Switch Signal
B3
DK GRN/WHT
1317
Fog Lamp Relay Output - Coil
B4
PPL
34
Fog Lamp Feed
B5
Not Used
B6
BLK/WHT
174
Low Windshield Washer Fluid Indicator Lamp Feed
B7
BLK
550
Ground
B8
PPL
1093
Fused Rear Defog Element Output
B9
Not Used
B10
LT GRN
1324
Fused Backup Lamps Feed
B11
RED
242
Fused Battery Feed
B12
ORN
240
Fused Battery Feed
C1–C2
Not Used
C3
PPL
524
High Beam Switched Ground
C4
ORN
340
Fused Battery Feed
C5
ORN
2340
Fused Battery Feed
C6–C8
Not Used
C9
ORN
1640
Fused Battery Feed (Uplevel)
C10
PPL/WHT
1035
Starter Relay Feed - Coil
C11
LT BLU
1620
Fused Trailer CHMSL Feed
C12–D2
Not Used
D3
YEL
525
Low Beam Switched Ground
D4-D8
Not Used
D9
WHT
193
Rear Defogger Relay Output - Coil
D10
DK GRN
19
Stop/Turn Lamp Feed - Right Rear
D11
WHT
17
Stop Lamp Output
D12
ORN
540
Fused Battery Feed
E1
ORN
1140
Fused Battery Feed
E2
ORN
140
Fused Battery Feed
E3
DK BLU
15
Turn Signal Lamp Feed - Right Front
E4–E6
Not Used
E7
LT BLU
203
Air Conditioning Refrigerant High Pressure Cut - Out Switch
E8
WHT
352
Headlamp Relay Feed - Coil
E9
Not Used
E10
YEL
18
Stop/Turn Lamp Feed - Left Rear
E11–F2
Not Used
F3
LT BLU
14
Stop/Turn Lamp Feed - Left Front
F4
ORN
640
Fused Battery Feed
F5
ORN
2240
Fused Battery Feed
F6
ORN
2267
Fused Heated Mirror Element Feed
F7
LT GRN/BLK
592
Daytime Running Lamp Relay Output - Coil
F8–F9
Not Used
F10
ORN
1140
Fused Battery Feed
F11
LT BLU
1320
Fused CHMSL Feed
F12
ORN
1540
Fused Battery Feed
•12193905
Pin
Wire Color
Circuit No.
Function
A1
ORN
40
Fused Battery Feed
A2
ORN
740
Fused Battery Feed
A3
BLK
28
A4
LT BLU
74
A5
ORN
1040
Fused Battery Feed
A6
BLK/WHT
451
A7
BLK
550
Ground
A8
Not Used
A9
PNK
3
A10–B1
Not Used
B2
PNK
94
B3
DK GRN/WHT
1317
B4
PPL
34
Fog Lamp Feed
B5
Not Used
B6
BLK/WHT
174
B7
BLK
550
Ground
B8
PPL
1093
B9
Not Used
B10
LT GRN
1324
B11
RED
242
Fused Battery Feed
B12
ORN
240
Fused Battery Feed
C1–C2
Not Used
C3
PPL
524
C4
ORN
340
Fused Battery Feed
C5
ORN
2340
Fused Battery Feed
C6–C8
Not Used
C9
ORN
1640
C10
PPL/WHT
1035
C11
LT BLU
1620
C12–D2
Not Used
D3
YEL
525
D4-D8
Not Used
D9
WHT
193
D10
DK GRN
19
D11
WHT
17
Stop Lamp Output
D12
ORN
540
Fused Battery Feed
E1
ORN
1140
Fused Battery Feed
E2
ORN
140
Fused Battery Feed
E3
DK BLU
15
E4–E6
Not Used
E7
LT BLU
203
E8
WHT
352
E9
Not Used
E10
YEL
18
E11–F2
Not Used
F3
LT BLU
14
F4
ORN
640
Fused Battery Feed
F5
ORN
2240
Fused Battery Feed
F6
ORN
2267
F7
LT GRN/BLK
592
F8–F9
Not Used
F10
ORN
1140
Fused Battery Feed
F11
LT BLU
1320
Fused CHMSL Feed
F12
ORN
1540
Fused Battery Feed
