ls swap harness question
Okay, doing a turbo 5.3 ls swap into my 97 camaro ss. I have an ecu and harness out of a 99 or newer camaro. The write up on converting this harness seems like a waste if what I have heard is correct. Will a 98 camaro harness plug right into my car? Obviously I will be deleting a lot of things out of the harness that I don't need but it seems that the under dash connectors and the inner fender connectors arethe same. Is this correct oror will it be just as much work with the 98 harness as with the newer harness? Thanks for advice!!!
LS1Tech Sponsor
If you would like use to rewire what you have or even if you just want to purchase some materials for what needs to be added just give us a buzz.
If you decide to DIY it and you post up questions we will answer them if we happen to catch the thread. Please keep in mind we are incredibly busy!
Bill
270-805-1777
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
