1995 4l60e interchange years
Old 10-09-2013, 10:26 PM
ROUDA's Avatar
Default 1995 4l60e interchange years
Hello, I have a 1995 4l60e auto transmission fresh rebuild beefed up and a 2000 stall. Question is can this trans work in a ls1 swap ? will the pcm be able to run it properly and I believe there mite need to be a adapter but not sure. So Im looking for someone that can answer this or that has used a lt1 95 auto trans with a ls1 Thanks
Old 10-09-2013, 11:24 PM
MasterTomos's Avatar
No. the ls1 style 4l60es are different than the lt1 4l60es.
Old 10-09-2013, 11:50 PM
superdave84's Avatar
The difference can be easily spotted in the cases. If there's a two part case, it's the later 4L60E. If its a single case, and all smooth like an old TH350, etc, it's the older one.
Both transmissions will bolt to the LS1, or any GM motor for that matter. The electronics, however, will not work. I am no expert but I THINK you can use the older model, but it will not shift properly, and may not shift at all. I think you could shift it manually but that would get very old very quick.
I would just sell the trans you have now and get the one that works right with the setup.
Old 10-10-2013, 10:31 PM
ROUDA's Avatar
yes two piece housing , I like the two piece any so much easier I believe it say pwm inside just not sure about it I read a long time ago that 95 was a stand alone year. I would sell it but I just rebuilt it and used good parts.
Old 10-17-2013, 11:19 PM
ROUDA's Avatar
can anyone else verify any of this
Quick Reply: 1995 4l60e interchange years
