Nitrous LS Notch 8.80@150
First time on spray, still workin the bugs out, nitrous shut off at 1000 foot due to window switch picking up lean reading. 1.27 sixty foot 5.57@123 eigth....with 8 deg timing pulled and leaving at 3200 on trans brake cuz track was weak. I usually leave at 4k. 25percent start building over 1sec. All on pump gas with a .065 jet. Shes got more in her for sure, stay tuned! Hope the track will have pics up soon but heres one on motor at INDY
6.0 with l92 heads. 402 stroker kit by slp/manley, callies crank, vic jr with 850 qf carb. heads n intake ported. custom grind compcam, powerglide with 5500 coan converter. 355 gears 8.8 rear with spool n 35 spline axles. Aje k member n a arms and crossmember. Driveshaft shop driveshaft. Kooks headers, aerospace brakes. 275 Mickey dragradials. weighs 2840 with me in it. And yes i drive this car. runs 9.7s on motor n has heater wipers and 10 point cage with full interior. upr anti roll bar as well as upr front n rear springs and adjustable rear arms.
