PS pump question? Need help
I saw a great thread that went over the GPM and PSI of the different LS power steering pumps, but it ended with the LS2 I believe. Does anyone know the GPM and PSI output of the 2012 L99 Camaro power steering pump. I am trying to put this in with an aftermarket rack and pinion setup. Does anyone know if the 05-06 GTO pump will bolt right up to the L99? I know they are in roughly the same location, just not sure if the brackets/pulley sizes are the same.
