old Muncie 4 sp to long crank block
a buddy asked me about using an old Muncie 4 sp/bell housing on an LS engine
as near as I can tell from his desc. it may be a long crank block
has anyone done this conversion-what flywheel would you use-prob a hyd throw out bearing, and some kind of adapter pilot bushing
stock older gen 1 bell housing?
The Muncie is no problem. But as far as I know no flywheel that will work with a starter is available for the 99-00 long crank. Easier to get a short crank motor.
https://ls1tech.com/forums/conversio...-ls-motor.html
