My 91 C1500 LS1 Swap thread.
#43
Just replace the rubber sections in the old fuel lines with fuel injection hose and double clamp each end with fuel injection hose clamps. You can buy the fittings that snap on to the rail and just clamp them into the hose. If you have a return less rail then you'll have to use the corvette filter/regulator.
#44
Well i tried mounting up the tranny last night and it didn't go well...so I'm gonna take out my engine out of the truck and try to mount the tranny and drop in the tranny and engjne together...
#47
Well Yesterday I got my friends cherry picker and the LS1 with tranny are in the truck already. I prefer to install the engine with tranny if there is no lift. Was pretty easy. And what i did to make sure the ls was a perfect fit with the tranny in the engine bay was i measured the end of the 350 motor mount to the end of the block and it measured 1ft 2in. on each side. So I got the Dirty dingo mounts and slid em to where it measures the same on the 350 and i mounted up the tranny to it put it in the bay and it fit perfect with the chassis mounts and the tranny crossmember. I'm happy with the dirty dingo mounts. Now im
#50
#52
Thanks man, and nice what mounts did you get? And I'm actually running my stock radiator. Got the 99 truck upper and lower hose and it looks good. Made my own hoses for the heater core. since one of the heater hoses goes to the radiator from the firewall i got a "T" from auto zone and cut the hose and made it go from firewall to water pump and radiator.
#56
Found out out i need a 3/8 to -6an fuel adapter so i just ordered that and fixed my clutch problem that i had and connected the o2 sensors...tomorrow i shall put on the fuel pump and work with the wiring harness a lil bit more. Oh and remember to make sure that the slave cylinder rod is on the fork, not under it or your gonna have problems like me...lol
#58
Replaced my fuel pump with a high performance fuel pump.... all i had to do was spice up 2 wires. Easy job.
Put on my driveshaft as well and now all i need to do is mate up the new harness with the old harness.
Cleaned up the intake and covers, had to cut so they could fit with alternator bracket and throttle cable bracket
#60
Heard its quiet should work good went in like it was stock, i liked how it fit.
