Auto meter gauges
Auto meter gauges
I am needing to hook up my auto meter speedo and tach? Do I need the auto meter sender for the speedo? Which wires from the pcm will I need for the speedo? Also which wires from the pcm will I need to hook up the tach. This is a 2002 ls1 t56
If the trans is outputting a signal from the VSS (which it should) you need a programmable speedo. The tach will run off the factory wire but might require a "pick-up circuit" to enable the gauge to read properly. Search this site for pick-up circuit and you'll find diagrams on what it all requires.
