can someone give me a 4l60e break down by years/compatibility?
Old 02-03-2014, 07:44 PM
Old_blue's Avatar
Default can someone give me a 4l60e break down by years/compatibility?
I have read many threads on here and would like to get a solid answer on this. Many threads only cover up to a certain year then stop. I am sure others would like to know as well.
Can someone give me a break down of what years the 4l60E transmission changed and what it is compatible with?
Basically, I have a 2008 4.8l motor and I am trying to find the right transmission. From what I am being told I need a 2007-2009 4l60E due to the wiring harness. Is this correct? Are there other tranny combos that will work for my motor? is there a stand alone computer for the transmission I need or is it all off of the vehicle ECM?
Thanks
Old 02-05-2014, 03:08 PM
Old_blue's Avatar
No one? TTT
Old 02-05-2014, 07:32 PM
pdsq98gt's Avatar
Do you have the harness and ECM for that 08 yet? If so you are pretty much going to need that 07-09 trans and TCM. Those transmissions have an internal range switch and input speed sensor. They also got rid of the fluid pressure switch assembly in those years.
Old 02-11-2014, 08:13 AM
Old_blue's Avatar
I have the 08 harness but don't have the ecm yet. Can I just get a different year 4l60e and tcm to go with it? Or will the ecm not work with it?
Old 02-11-2014, 06:47 PM
pdsq98gt's Avatar
It would be a lot less work if you just get a trans from that year of vehicle because if you used a PCM from an older vehicle to run the trans you would have to repin connectors among other things.
Old 02-13-2014, 10:09 AM
Old_blue's Avatar
Thanks, It may be a lot less work but finding one proves to be elusive.
Quick Reply: can someone give me a 4l60e break down by years/compatibility?
