Need help!! 67 el camino ls1/t56
Old 02-18-2014, 11:29 AM
UZI67ELCO's Avatar
Default Need help!! 67 el camino ls1/t56
Today 09:23 AM
UZI67ELCO
Good morning guys, I'm working on my 67 el camino project for a year and a half now. im running a stock ls1 out of an 2001 Camaro ss with a t56. Im at the last part of the project and im running into a little problem. Once I fire up the engine it runs great. I let it run about 5-10 mins and no problems. Once I shut it off and try to restart the car again it wont start up again.
I have constant 65 psi on the fuel rails. so its not a fuel problem. I have continuous voltage going to the computer. any ideas or suggestions what can it be?? this is the breakdown where I have everything connected to
PCM BLUE CONNECTOR:
#33/ BLUE WIRE TO FANS
#19/ PINK WIRE TO KEY POWER
#57 ORANGE HOT ALL THE TIME
#20/ ORANGE WIRE HOT ALL THE TIME
PCM RED CONNECTOR:
#9 GREEN TO FUEL PUMP
#10 WHITE TO TACH.
PLEASE GUYS I NEED HELP!!
Old 02-18-2014, 12:44 PM
1964SS's Avatar
So it only started up the one time? have you tried starting fluid? It's either injectors not getting power or engine not getting spark.
Old 02-18-2014, 12:59 PM
UZI67ELCO's Avatar
it'll start twice. then after that it wont start up. I have to wait like 2 hrs and it'll start up again. it does smell like fuel a lot. but im getting 65psi at the fuel rails.
Quick Reply: Need help!! 67 el camino ls1/t56
