Oil pan ls1 into 67 camaro
Putting LS1 in a 67 Camaro. Using a standard adapter plate not a 1 inch setback. Need to get a good oil pan to fit my application. heard of a holly retrofit oil pan that works...what do you think out there? Or could have the pan custom cut by Street&performance? Already wasted money on an LH8 oil pan that hangs too low any feedback would help. Thanks Lance
Need to notch the fbody pan to work on a 1st gen. Street and performance in Arkansas does the notching service.
Others have been discussed here... Do a quick search..lots of info...sticky section...Sorry you learned the hard way with the LH8 pan. I've read the Holley 302-2 pan works.good luck!
https://ls1tech.com/forums/conversio...o-ls-swap.html
https://ls1tech.com/forums/conversio...ld-thread.html
https://ls1tech.com/forums/conversio...uestion-2.html
