tranny and throttle cable question
if im gonna use a th350 and run a factory computer which normally operates the 4l60e what do i do with the wires that would normally operate the tranny?
I dont want to delete them cuz eventually i plan on adding a 4l60e. will the computer error out because of this?
also,,, do i use the throttle cable from the vehicle or get the one from the donor vehicle?
You would need to tune the 4L60e code out of the ECM and just tuck the wire away (if you don't want to delete/cut them).
You are going to have to run either a) a DBC and add a lever on the TB DBC cam for the trans cables or b) a Manual Valve body in the TH350 and shift the trans manually.
There are some others that have run a TH350.. try searching for those threads.
BC
BC
i plan on putting in the BOPC type cable that hooks to the gas pedal rather than the chevy type that runs up to where the carb used to be for the kickdown.
im still confused on the throttle cable though, pardon my ignorance but whats a dbc? and which cable do i use, the cars original or the donor one?
I would grab both cable, cable bracket, and pedal. Bowtie overdrive has your kick down solved.
http://www.tvmadeez.com/ls1_cam/
From what I know you will still need the vss part of that harness. you can get the vss from Dakota digital to either hook up a cable speedometer or electronic.
