G body Moroso oil pan ?
Anyone with a G body running a Moroso 20140 or 20141 oil pan wondering how much clearance there is between the frame and what mounts did you use pics would be helpful!
They have pans with the filter mounted on them now and they are the same basic pan as the numbers i listed so i figured i would have more luck finding some with the older versions that had the remote mount. I know the 20140 should work fine but i like the 20141-20143 versions with the ramp better!
It seems like the moroso 20141 ramped pan is very similar to the factory truck pans in the front area has any one used one of them? Just using it as a comparision they hang down way low!
