2006 gto retrofit wiring diagram?
Has anyone created a DYI retrofit wiring drawing for the ls2 gto's like found in this thread for the 98 & up ls1? https://ls1tech.com/forums/conversio...schematic.html
Thanks
Rocky
Thanks
Rocky
Are you using the E40 PCM? If so I just got finished with a similar swap, to the GMT0800 wiring harness. I believe all of the circuit ID's are the same so you should be able to use it.
Not sure if the info you need is in here, but here's a good link:
http://www.ls2.com/forums/showthread...ng-Information
