Tanks inc fuel pump assembly
Old 05-29-2014, 12:08 AM
SPOOLIN Z28's Avatar
Default Tanks inc fuel pump assembly
Anyone using one of their fuel pump assemblies? Wanted some insight on what people think of them. This will be on a budget 67' camaro 6.0 swap. Thanks
Old 05-29-2014, 12:19 AM
sprech's Avatar
If you are talking about this one, it's the one I plan on using in the Cadillac build. It seems to be a pretty good setup for less money than the Aeromotive one.
Old 05-29-2014, 12:29 AM
Yes this would be correct.
Old 05-29-2014, 12:37 AM
sprech's Avatar
Something else you may want to look at is the Spectra efi tank, I think the p/n is GM32BFI. I used it on the '69 Firebird and the only thing I did was replace the provided pump with an AC Delco unit, it seems to be of good quality.
Old 05-29-2014, 12:55 AM
bczee's Avatar
Many are using them, I am using a the PA4 unit.. no problem.
But it is a bit tall for your tank, you have to mod it a bit to work.. not a big thing.. you need to shorten the depth a bit more than the depth that it is setup for. You just have to drill a few more holes in the support bracket.
Or you can mod your tank Like I did.. you can read about what I did in my Nova Build thread (in my sig) and add a sump that both dropped the tank another 1" and added internal sump inside the tank.
BC
Quick Reply: Tanks inc fuel pump assembly
