Will a truck AC compressor fit an F-body bracket?
I'm in the basic planning stages of adding AC to my swap. I have the F-body belt spacing, so I need a compatible compressor. Will my truck compressor fit the bracket or will I need another compressor?
I'm in the same boat, sorta. I have found that there are many different A/C brackets as well as compressors. The Sanden 508 bracket is about $175 and the number of ribs does not match the crank pulley. OEM compressors need a special bracket depending on that year/configuraton. OEM also need special hose manifolds to attach to the pump. Want to keep my mount low and tucked in which will be tight to say the least. Many options, and cost/problems with each. I think that the only way to go is to look at the space for your application and add up the cost. Not much of an answer but at least you know you are not the only one scratching!
