Truck manifold fuel rail swap?
Old 06-27-2014, 01:00 PM
nyciti's Avatar
Default Truck manifold fuel rail swap?
Hi,
I am about to do my swap, my motor is out of 2002 Escalade w/two lines, I see later year trucks have a single line. They look like they can, but can I swap the fuel rail? I would rather run the vette style filter / regulator if possible.
Thanks,
Old 06-27-2014, 06:23 PM
Beanslsxnova's Avatar
Yes, they interchange with no modification
Old 06-28-2014, 09:51 PM
spacemanspif's Avatar
I think that flex fuel injectors are different lengths than regular truck injectors. You may need spacers depending on what injectors are on your engine and what ones the returnless rail is designed to work with.
Old 06-28-2014, 10:13 PM
superdave84's Avatar
^^^ This is correct
Quick Reply: Truck manifold fuel rail swap?
