A body rad to LS F body wp hoses ?
Got the usual A body rad neck locations. Using F body wp, so that neck faces forward. Also using straight t-stat neck conversion on bottom. (Got the info if anyone needs the same) what hoses are you guys using with straight necks?
When I got my 72 olds cutlass, it came with the radiator and hoses. I was surprised both the top and bottom hoses fit just by cutting a bit off.
On the top, I spliced in an adapter for hose size with a steam fitting:
Bottom just needed a couple inches cut off, mated up with the stock angled thermostat housing.
