411pcm to p59 pcm swap
I am looking to swap a p59 blue/green pcm into my camaro and I'm trying to figure out what all I have to repin. I know there is a few grounds I have to add and that the o2 heaters need to be moved from the fuse box to the pcm. Besides that what else needs to be moved around and/or turned off? Looking at multiple different 99-02 f-body pin outs I can't find oil pressure? What pin is it? Also it looks like the gto blue/green pin out I'm looking at has a fuel tank pressure sensor? Is that actually monitoring the pressure in the tank or a fuel pressure sensor that's located in the tank/pump bucket and I can't pin in my pressure sensor there and it will work? Any help is appreciated
