GTO oil pan plug popped out! Oil everywhere
Old 11-04-2014, 04:28 PM
apiazza2010's Avatar
Default GTO oil pan plug popped out! Oil everywhere
I have an bmw 325i with an ls1 swap. I used a gto oil pan and had to plug up the extra dipstick hole. I forgot to do that before putting the engine in the car, therefore I used the correct PN from Chevy for the freeze plug. I tapped it in until it stopped moving. Today I went for a ride and I started seeing white smoke coming out of the front of the car, and realized the plug was GONE
Did I install it wrong? What other solutions do I have, dropping the oil pan involves engine removal in my car unfortunately.
Thanks for the advice
Old 11-05-2014, 06:53 AM
Project GatTagO's Avatar
Received 1,394 Likes on 880 Posts
Got a PN for the plug? I need one and personally I plan to use locktite when I install mine.
Andrew
Old 11-05-2014, 09:49 AM
truckdoug's Avatar
gm #12557520
it's probably a steel alloy, maybe try a magnet?
i'd imagine it's more likely it went OUT rather than IN, but i'd want a "peek at the turkey" just to be sure.
Old 11-05-2014, 07:01 PM
kwhizz's Avatar
Find out what size the hole is and try and match it with a tap size........tap it and put in a set screw with sealant on it....
Ken
Old 11-18-2014, 12:01 AM
I ended up dropping the front subframe, tap the bolt from the inside with a metric 10.5 tap and bolt with RTV.
Worked perfectly
Quick Reply: GTO oil pan plug popped out! Oil everywhere
