PRC Radiator Woes - Houston
I have an LS3 in a 69 firebird. I (apparently) didn't mount my radiator correctly (even though the mounts are designed for these applications) and now it has cracked for the second time. Notwithstanding that I guess I need to weld some tabs on the bottom of it so that it will be supported from the bottom, I need to try and get it fixed. A racing buddy of mine said there is a shop in Houston that can repair these things; it is leaking on both sides between the tubes and the header.
Can someone direct me to a place where I can get this repaired? I'd rather not have to buy a new one if I can get away with it.
