MKIV Supra LS swap, needing shorty header ideas
I have always loved that generation of Supras. Around here they are rare and very expensive.
Are planning on running a turbo sometime? No need to spend money on headers when factory manifolds can be used for either application.
Hole behind the headlight...
Borg 80mm I plan to use...
Turbo setup I plan to steal lol....
Yeah, I'm not planning to run power steering. If I do I will be using a DSM power steering pump with a custom bracket.
Got a question, I'm using the Mr. Gasket 10 gph fuel pump. I'm wanting to know if the pump will be able to suck the fuel from the tank through the stock fuel pump holder using npt of course or should I install a bulkhead fitting in the plastic gas tank and gravity feed it ? Supra gas tanks dont come cheap, so if s the ability to suck the fuel up out of the tank I would rather do that instead of drilling a bulkhead fitting into my tank.
